メインコンテンツにスキップ
Model M7886 / 450 MHz or 500 MHz PowerPC 7400/7410 (G4) Processor
Why does my Cube take for ever to power on
Hi guys,
so recently I‘ve noticed that my Cube takes really long to turn on. Like minutes. Also when I put the cable into the outlet it takes a couple of minutes for the green led on the bottom to turn on. Does anybody have an idea what could cause the problem?
Also I might have to note that I live in Germany so we have 230V mains voltage, if there is any known defect in European Cubes.
Thanks for your help!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@lambda possibly running into issues with either your power brick or your DC-DC board. You do want to check the output of those with a meter and see. Use these guides Power Mac G4 Cube and teardown to check things over.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
--- さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 100
