メインコンテンツにスキップ
SSD drive rebooting, reinstall OS X
Hello,
I m a bit new here,
My question: I having problems install reinstalling OS-X
It worked fine till I restarted my laptop. The now I'm getting the question mark yea!
When I open utilities and want to reinstall Mavericks OS-X. Than it's asking to select the drive for install, but there is no longer a drive to see. When I open Disk Utilities, there is the BASE System OS-X, but I don't see the SSD drive.
So if I try to reinstall OS-X using a flash USB, it stops have way, giving a stop sign.
How do i solve this? Suppose I have to reformat the drive, how do it manage this?
The SSD should work fine, it did , but now it's no longer in the list.
Any answer for this problem is welcome! Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント
Do you have access ta a Windows PC?
さんによる
Please tell us your exact machine.
さんによる
macbook pro 17 inch
さんによる
コメントを追加
1 件の回答
最も参考になった回答
If you cannot see the drive then you cannot format the drive. You should run diagnostics by holding down d during startup. Most likely you have a failed ssd and it will most likely need to be replaced.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Jan さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 6
今までの合計 167
