メインコンテンツにスキップ
Repair information for the Samsung Galaxy Tab 12.2, released in 2014. Model numbers: SM-T900, SM-T905.
20回答 すべてを表示
How to remove motherboard Anfang fix battery connector
I had the same problem as many others with the flickering, rebooting, not charging of the galaxy note pro 12.2 wifi. So I opened the back cover of the tablet and found the battery connector sitting in place but loose. When I touched it a bit too hard it moved and when I tried to push it back it fell apart. Now I have to replace it completely but can find No information on removing the motherboard. I did find a really good video on your website for the 10.1 I believe but my motherboard has a couple of more cable ribbons attached and I am not sure how to remove them.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
最も参考になった回答
Here is a guide on replacing the battery if that helps.
Here
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks but I am looking to replace the battery connector and have to remove the motherboard from the tablet to fix it.
さんによる
コメントを追加
回答を追加する
Wayne De Groot さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 11
今までの合計 796
