メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
耳全体を覆うフルサイズのヘッドフォン、通称サーキュマル・ヘッドフォンの修理ガイドとサポートです。
Right ear in Sennheiser 461G is completely silent. Help?
Tripped over the wire of my Sennheiser 461G over-ear headphones (it only goes in to the left ear and is connected through the headband) rushing out of the house and when I got back only the left ear plays audio. I was really in love with these headphones and since they just went out of manufacturing the price to replace is high.
I took apart the headband and the wire inside connecting to the right ear seems intact but it might need a replacement. I don't know how to get to the speaker.
What could be broken and how should I get to it?
EDIT: This is my first post here. Hi all! Let me know if I did anything wrong.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
One side not working is usually a case of a broken wire either as it goes into the jack plug or as it goes into the headphone, both places where it tends to get bent and stressed the most. If it's at the jack plug end you can chop the plug off with a couple of inches of wire and solder a new one on - but you need to get the connections right. If it's at the headphone end you'll need to find a way of disassembling it. You can get a cheap audio lead with a jack plug on each end, chop one plug off and use the remainder to replace the whole headphone lead.
As for disassembly, first of all, remove the foam ear pads if you can. You may then find some screws hidden under a soft covering, which you can locate by feel, then piece the cover with a screwdriver to undo them. It may still be held together wit clips. The iFixit jimmy is great for releasing these (or a similar tool, or even a knife, but take care") - insert it into any crack you can find and pry it open. But having got it open you may find you simply have to resolder a wire that has got yanked.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Actually my headphone’s both side is working with androids but the left side is not working with my iphone I don’t why
さんによる
コメントを追加
回答を追加する
Luciano Malavasi さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 38
今までの合計 7,044
