My Gopro HeroPlus lcd, back lcd is broken
Can you purchase a new rear touch screen and replace it ? My one is broken/cracked
If you can, Is there a tutorial to show me how ?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi @chrisjohn ,
This is only half an answer to your question.
Here is a link to a video that shows how to remove the LCD screen from your camera.
If you do decide to follow this video ensure that you disconnect the battery before attempting to disconnect the video cable and remove the screen. Also reconnect the battery after you have replaced the LCD screen and connected the LCD screen cable.
I've searched online but cannot find a replacement lcd screen for a Go Pro Hero + LCD camera. You may have better luck. If you cannot find one either, check if there is a part number stamped on the back of the lcd screen in your camera. If there is, search online using just the part number only and see if you get any results.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 13
今までの合計 102
1件のコメント
Thank you for your quick response, hopefully I can find an lcd replacement, if I do, I’ll post where to get it from.
Chris john さんによる
