メインコンテンツにスキップ
The TI-84 Plus CE is a graphing calculator released in Spring 2015 by Texas Instruments. It includes a 2.8 inch color screen, USB port, apps, storage, and a 1200 mAh battery.
79回答 すべてを表示
Why is part of my screen black?
Part of my screen is black-blocking numbers-, what is the problem and how can i fix it?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
8 件のコメント
Are the pixels dead? Or just not working while calculating (working when graphs are drawn).
さんによる
@ulees Everything in the calculator works, i just have a big black half circle sticking out from the side of the screen that’s blocking numbers
さんによる
@summerrose Is it dead pixels or something between the glas?
さんによる
@ulees i actually don’t know, what would be the solutions for both problems?
さんによる
@summerrose There is one solution for both problems and it's warranty. If you don't have it then there isn't solution for dead pixels problem. If it's something in the between of screens you can teardown your device and try to remove it. I doubt that is the last one.
If this helped please let me know so i type a full disclosure in answers tab so people can find it easier .
さんによる
3件以上のコメントを表示
コメントを追加
1 件の回答
選択されたソリューション
Hello,
so me and OP of this post resolved the issue in the comments so if you don't mind reading all that.
If you are a little bit lazy just read the last two it contains it all.
Thanks.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Summer Rose さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 17
今までの合計 2,970
