メインコンテンツにスキップ
2014年9月19日に発売されました。この5.5インチサイズのスクリーンをもつiPhoneは、iPhone6の拡大サイズ版です。
1525回答 すべてを表示
Black screen stuck dfu error 4005
Hi Everyone
Without the screen I cant get it in dfu modus again? Please help me out..
I tried some options from Jim and people
Says the screen off works sometimes
So anybody know why that not work for me?
Had a touch probleem and fixed it bij putting a sim card in between the cables and plate. Them I saw one pixel so get it off again before that Turned off the phone when it was still connected to to MB so set a little peace of tech tape in between instead off the simcard put everything back together and now it is dead! Tryed Almost everything software wise.
Only thing what I can find is the the screwdread where the under screw from the lcd plate go's in. In broken but put in back on its place... so am so frustratred been busy for days. Got no money left
REALLY HOPE SOMEONE WILL HELP ME.
REGARDS WENDY
8 minuten geleden door wendy janssen Bewerk Verwijder
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
This is a belated answer so hopefully it can be of use to folks who search for and find this question.
I guess there are two issues here. The first one is that this phone seems to suffer from Touch Disease. Placing sim cards or other objects to apply pressure on the Touch IC is at bets, a temporary solution and at worst, one that will make the original issue (broken traces) even worse.
However in this case, it sounds like there was some damage to one of the screw standoffs for the screen connector retaining bracket. Underneath those standoffs are very tiny traces of copper and they can be damaged by either an over tightened screw digging into the copper or by the physical damage caused when the standoff is ripped from the logic board. This type of damage would cause all types of boot errors and the only way to potentially correct this is via a micro-soldering repair.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
wendy janssen さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 494
