メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
AppleのiPad AirのWiFiモデルのバージョンはモデル番号A1474、スペースグレーと、シルバーがあり、カスタムA7プロセッサーが装備されており、容量は16、32、64、128GBがあります。
Red lines with booting
Dear people,
When i was charging my iPad Air 1 this screen came up.
It totaly freezed up and with the powerbutton and homebutton pressed in it finally turned off.
I've been trying to charge the ipad for 1 day on the charger, didnt work.
Then i removed the screen and disconnect the battery, didnt work.
Does anyone have an idea how to fix this?
Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
I haven't seen this screen pattern before so I can't offer up a "solution". Did anything happen to the iPad in the days or week prior to this issue? Perhaps it was dropped, damaged, contacted water or was repaired.
At any rate, this device has to be opened up and tested. Perhaps it's the LCD but I suspect a logic board issue. A repair shop that does micro-soldering repairs should be able to troubleshoot this.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Minho! Thanks for your reply!
Nothing happend to the iPad it was just charging.
Do you know which IC or is it the charging electronics?
さんによる
Like I said, it could be multiple things and I haven't seen this pattern before. It could be a damaged LCD, LCD drive circuit or a flex/connector issue.
さんによる
コメントを追加
回答を追加する
Luuk Toonstra さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 526
