Why is my back camera and flashlight not working? BUT
But when im on Facebook messenger, my flash works and the camera works BUT its zoomed. What seems to be the problem? I dropped it awhile ago and the camera glass cracked too
I had this issue, it means either one of the cameras are broken or if you had it replaced they didn't plug in one of them correctly. I had the same issue, have them or if you replaced it, make sure both cameras are plugged in correctly
このアンサーは役に立ちましたか?
I forgot to add that i dropped it awhile ago. The camera glass is cracked.
In that case one of the cameras must of been broken. You might need to get your cameras replaced in that case
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 2,339
