メインコンテンツにスキップ
Sony Computer Entertainmentによって製造されたPS4と通称で知られるテレビゲーム用コンソールです。2013年2月20日に製品の発表、2013年11月15日に発売されました。
1697回答 すべてを表示
ps4 turns on for a second, beeps 3 times then shuts off
My console was overheating so I tore it down and replaced the thermal paste (4ish year old console). The fan was running before, but clearly not well because the console shut off on me when I was playing a game. The inside is clean and free of dust, new thermal paste and pads have been applied. Put it back together and now I'm getting a single beep, fan kicks on, then it immediately beeps 3 times and shuts off.
Any ideas?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 14
10 件のコメント
sounds like you should try to contact the console guru @tronicsfix ON HERE https://www.ifixit.com/User/721921/Troni...
さんによる
Did you remove the entire bottom plate and clean the heat sink?
さんによる
@tronicsfix yes, the heat sink is clean and clear of dust
さんによる
Hmmm...well unfortunately, there's just no way for me to know what's causing it without being able to test it. Looks like you've tried all the easy stuff.
さんによる
Just a long shot, but you could try removing the power pack, and reseating it, making sure it makes a good connection.
さんによる
5件以上のコメントを表示
コメントを追加
7件の回答
ベストアンサー
Seems like it was power connection on the power supply. After tearing it down and starting again, it's working great. Thanks guys!
このアンサーは役に立ちましたか?
スコア 4
3 件のコメント:
what do you mean by this cos i did the same and know its happening to me
さんによる
You have to make sure all the bending ground pins are not bent down if there not all grounding the mother board correctly it won't turn on. I had the same problem I took it back apart bent all the pins up a little and put it back together and works perfect now!!
さんによる
if it still doesn't work.. when removing the mother board you expose the apc from the old thermal paste, apply new thermal paste on apc and bang bobs your uncle, runs like new concluding you cleaned the fan too
さんによる
コメントを追加
I had the same issue after a clean out. I’d used regular heat sink compound (white colour)and after striping down again used a high-density silver heat sink compound (grey colour) and didn’t apply as much. Worked for me, don’t know if it was a fluke. Good luck
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
If the PS4 was left off for an extensively long time, the fan may be dusty. Try cleaning off the fan for the console and restarting it. Thank you!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Deep clean, motherboard & battery out.
Plugged it in to play and BEEP, BEEP, BEEP. Fan kicks in, goes mad then shuts down (red light)…
Now what?! Noticed the thermal paste is old and flaky and hardly anything in it
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I have the same exact problem with mine
さんによる
コメントを追加
i think i broke the lil part on the left side of the motherboard and i’m have the same problem, when i turn it on it’ll beep three times then turn off but it gives me a message that the console is too hot, way to fix it?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
You have 2 options replace the thermal paste or buy a new power supply with a thermal paste jusy in case i have th same issue right now
さんによる
コメントを追加
First step: USE THERMAL PASTE
Mine just worked today after 1month of desperation of fixing . The Thermal toothpaste really surprised me in one application. While there are the blue/white light of death but mine is turn on and turn dead after 3 beeps. I cleaned it first time and the problem started happening. It was a bit trouble to find remedy for it like idk what really was the problem but it was just a simple thermal paste problem. So, I bought the thermal paste and i can hear the jet once again. Oh yeah, it fixed overheating as well.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
But where did you put the paste?
さんによる
コメントを追加
Mine turns on fans goes insane then u hear BEEP BEEP BEEP then the fans turns off so does the PlayStation I opened it up cleaned everything put on new thermal paste and tried it and it didn't fixed it I also cleaned out the
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Kayla HUll さん、ありがとうございました!
統計データ:
過去 24時間: 10
過去 7 日: 43
過去 30 日: 228
今までの合計 84,083
