メインコンテンツにスキップ
2017年9月に発売されました。モデル番号はA1863、A1905。GSM もしくはCDMA/容量は64か256GB/ゴールド、シルバーとスペースグレイ
873回答 すべてを表示
Can I replace the entire rear housing?
I broke the rear glass on my iphone 8. It looks really hard to scrape off the glass and replace that part, so I was wondering if I can replace the entire back of the phone? I could just take out all the parts and transfer them, but the wireless charging coil looks like it's near-impossible to remove successfully. Does anyone know where I can purchase a rear housing including the wireless charging coil? Am I even on the right track with this?
Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 6
コメントを追加
4件の回答
最も参考になった回答
You can do it yes.
How to assemble iPhone 8 back housing?
このアンサーは役に立ちましたか?
スコア 6
3 件のコメント:
Do you know where I can buy the part including the wireless charging coil?
さんによる
The wireless charging coil can be removed, heating it with the heat gun can make it easy to be removed. The iPhone 8 backhousing is not available now.
さんによる
Mobile sentrix OEM Pulls
But also I heat the back of old housing and crack at glass making wireless charging coil come off or fall out
さんによる
コメントを追加
I have kind of the same problem, but - yet still a little worse:
My iPhone 8 has been dropped on a parking lot with an uneven surface - and run over by a car!
So, the entire back housing is bend quite a lot (strangely enough, neither the back glass or the screen seems to be damaged at all).
But it looks odd, and being the skilled industrial technician I am, I’ve tried to bend it back into the correct shape. This cannot be done, since the aluminium kinda hardens the first time it is bend out of shape - and cannot be forced back to its original shape.
So, it would be very appreciated if anyone could help, regarding where I can buy a new back housing.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Mobile sentrix highly recommended testing the phone with new screen before attempting repair
さんによる
コメントを追加
yes you can buy a back glass with mid frame and small parts installed or with a charging coil installed or just bare.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Yes you can however stuff sold in the western world is not cheap which is sourced out of china anyway but below is the link to what you are looking for.
https://www.amazon.ca/Vimour-Housing-Rep...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
fdsajky675 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 34
今までの合計 10,410
