メインコンテンツにスキップ
モデル番号A1318/ 32もしくは64GB容量
299回答 すべてを表示
Why were the volts of the second battery decreased?
One day, I realized that my iPod Touch wouldn't turn on, so I opened it and I diagnosed that the volts of the battery weren't 3.7 (as they had to be), but 2.1! So I replaced that battery with a new one, and my iPod worked successfully. But after three days, it stoped working again! Then I checked again the battery and the volts were 3.04! Could anyone help me, please?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
ベストアンサー
The voltage should increase when you charge it (as far as I know) so if it's not charging then it could be something else. Like a problem with the dock conector.
このアンサーは役に立ちましたか?
スコア 1
15 件のコメント:
Thank you for your answer BUT I am not sure that the dock connector has any problem, because:
1st) Before the second battery broke down, it was getting charged and
2nd)I had exactly the same problem with my first battery but, as I wrote before, my second battery was getting charged.
さんによる
George, I am sorry not sure why you say your battery got charged. How did you check that?
さんによる
So your saying that after the first discharge it will charge up again, but won't hold it's charge after that?
さんによる
I have just been reading that some People have just restored their iPod In iTunes and this has fixed it. Are you still able to turn it on? Or is it completely no responsive?
さんによる
To oldturkey03: The second battery got charged 3 times and then it broke down.
To Michael C: As my second battery had broken down, I opened my iPod Touch and soldered the battery again, and then I connected only the Lcd Display and it turned on again, BUT when I connected all the other stuff (Metal Backplate and Front Panel) it didn't turn on. Then, I tried again only with the Lcd Display, but it didnt turn on...
さんによる
10件以上のコメントを表示
コメントを追加
3.7v is the nominal voltage for a lithium polymer battery cell. If you look at a graph of the amount of charge left in the battery, and what voltage the battery is at, the majority of that graph would be at 3.7v. These cells, however, when fully charged, reach 4.2v, and when your iPod shuts off, it should be between 2v and 2.5v. This is because the battery can be permanently damaged if discharged below 2v. In this case, your battery is functioning perfectly, so your issue is with something else in your ipod
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
+ Yep been saying the same thing. It's not the Battery.
さんによる
I agree, not the battery!
さんによる
コメントを追加
回答を追加する
George さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 1,191
