Why won't it shut off?
My g pad is frozen on the secure start up screen. I put in my pattern and it said to shut off and restart to unlock device. But now its frozen. And wont shut down for a hard reset. What do I do?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi,
If the tablet is still on, then here is the ifixit LG G Pad 8.3 Battery Replacement guide.
Use the guide to disconnect the battery from the systemboard in the tablet. Once it has turned off, reconnect the battery and start again.
Alternatively wait until the battery has discharged enough for the tablet to shut down then fully recharge the battery before attempting to turn the tablet on again.
このアンサーは役に立ちましたか?
過去 24時間: 6
過去 7 日: 12
過去 30 日: 33
今までの合計 1,383
3 件のコメント
Hi,
Have you tried holding the power button until it force shuts down?
jayeff さんによる
Good morning! And to answer your question, I have held the Power button down for several minutes to no avail.
william armstrong さんによる
Thank you for the info. I already done that. I believe that the power button is not working. When I got it apart it looked like it had been poked by something very pointed. I believe it either severed or disconected some wires in the ribbon. I would try to jump start it off the board, but can't find the "ground" and don't want to fry it. I can get a new starter/volume button for about 6 bucks.
