メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
My iPod is frozen says I pod disabled?
my iod is frozen on the open screen i have shut it down several times will not work
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 21
2 件のコメント
my ipod dont worksay disabled
さんによる
This worked for me thanks!
さんによる
コメントを追加
7件の回答
最も参考になった回答
From what i understand is the ipod is frozen and you want to restore it. but you can't because it is locked?
if you havn't restored it yet, try that. if you can't restore it because it's locked with a password, then put it in recovery or dfu mode then restore it...
recovery mode
-power + home until it resets
-lift up off the power button while still holding down the home button untill --
-you should get a screen telling you to connect to itunes
-connect to itunes and restore
if it still asks for a password then put it in dfu mode and try restoring it
--dfu mode is a little bit harder and you may have to try it a few times--
-plug it in to a computer with itunes
-right when it resets start counting 1 1thousand 2 1thousand 3 1thousand. after 3 1thousand lift up off of the power button while still holding down the home button
- keep holding down the home button untill it shows up in itunes (will take 3 to 12 seconds, and you will know it is in dfu mode when it shows up in itunes but the ipod looks like it is off)
-restore it
このアンサーは役に立ちましたか?
スコア 12
3 件のコメント:
Answer #1 by Ryan Mar worked perfectly for me :D
さんによる
Ryan, you are amazing, Thank you!!
さんによる
Thanks so much this worked for my daughters iPod nano
さんによる
コメントを追加
Have you tried to do a hard reset?
Press and hold both the Sleep/Wake button and the Home button for about ten seconds, until the Apple logo appears. Please respond with results.
Thank you
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Try a soft reset first:
1. Press and hold the Sleep/Wake button on the top of the unit until a red slider appears
2. Drag the slider.
3. Press and hold the Sleep/Wake button until the Apple logo appears.
If a soft reset doesn’t work, try a hard reset:
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
I have a question about your answer.... where is the sleep or wake button located? and the menu button is the circle at the bottom right?
さんによる
it's the button on the top and the center button is the home button
さんによる
What if my power button doesn't work?
さんによる
コメントを追加
With no cables attached to the ipod and itunes installed:
1. Hold wake/sleep button down until prompted to slide to off to power down.
2. Slide to off with no cables attached.
3. Hold home button and attach cable to computer ipod should automatically turn on.
4. Click on restore ipod option itunes will prompt you for.
5. Wait for itunes to tell you it is done restoring the ipod.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
got problem w my ipod touch. Its ask to connect to itunes n my home and power button r not working. can you help me?:"((((
さんによる
That sounds like a hardware issue that would have to be resolved by taking it to someone skilled in small electronics.
さんによる
コメントを追加
you put your code in wrong too many times didnt you! or someone did on your behalf, download a program called recboot and put your ipod into recovery mode, connect to itunes and it will restore the ipod to factory and re sync your last backup!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Amy you can download a program called redsnow it had an option to create a custom restore file which will put you into DFU mode for restore especially designed for people with a broken button, then try instructions above for rest, or a program called tiny umbrella can put it in recovery mode at the click of a button.
さんによる
コメントを追加
You can try to use recovery mode to refresh the frozen iPod.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Yes iPod desabled comer to tu
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
amanda さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 12
過去 30 日: 37
今までの合計 37,974
