メインコンテンツにスキップ
The QiCycle Folding Electric Bike is Xiaomi’s first foray into the world of e-bikes. It has a 250W high-speed motor powered by Panasonic 18650 lithium batteries. The Shimano Nexus 3-speed gear hub in combination with the torque measurement sensor gives you up to 45km bike power on a single charge. It also has a trip computer can connect to your smartphones via their special app and is–of course–foldable.
53回答 すべてを表示
Nexus gear 2 skips
Hi,
Please can someone help me with the gears? I received my bike on the 28th of this month and I have successfully upgraded to latest firmware. The problem I am having is on the 2nd gear when i pedal it feels like it is skipping, it is not pedalling smoothly. 1st and 3rd gear seem fine and don’t skip.
Any ideas how i can fix this? I notice the yellow dot in the nexus gear is not in the correct lines.
Thanks Az
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
選択されたソリューション
I fixed the problem. It was easy to fix. Here is a step by step:
https://translate.googleusercontent.com/...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have the exact same issue, did you find a solution?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Yes I fixed the problem. It was easy to fix. Here is a step by step:
さんによる
コメントを追加
回答を追加する
Az Rahman さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 1,092
