メインコンテンツにスキップ
2.4GHz, 2.7GHzもしくは2.8GHz クアッドコア Intel Core i7 プロセッサ (Turbo Boost 最大 3.8GHz) with 6MB 共有 L3 キャッシュ。
274回答 すべてを表示
MacBook suddenly shut down and will not turn back on.
My MacBook suddenly shut down with about 17% battery left. We tried the shift, control, option, power key buttons and held them down simultaneously for 10 seconds. Then plugged in the power cord and hit the power key. The laptop turned back on. We entered our password to log in and it was loading at the bottom. Then it suddenly shut down again. Now we cannot get it to turn back on at all.
Suggestions??
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Just to confirm, you cannot turn on your MacBook even with the power cable plugged in?
さんによる
Correct. The power cord is plugged in and it is lit up green saying 100% charged.
さんによる
コメントを追加
2件の回答
最も参考になった回答
Clean the cooling system, replace the thermal paste, and if you see anything that looks like corrosion or liquid then scrub the board with a toothbrush and 92% alcohol. and if you still have problems you may have to replace the magsafe power adapter and the keyboard with power button. This will be assuming liquid damage is present. Sometimes people are un aware that they have liquid damage. It can happen if a friend spills something on it, liquid is present on the counter, or moisture is somehow present. This will also help with a cooling system issue although in rare times the thermal heatsink has to be replaced.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Hi i had a problem with my macbook pro 2 days ago when i was using my mac suddenly shut down and not turning on, i had try to charge my mac but charging light doesnt showing i used 2 charger they are same that means not charging my macbook. I coundnt see any light around my mac’ now my mac is completely dead.
Do you have any solution please ?
さんによる
コメントを追加
I would give brucewark's suggestion a try here:
How to bypass the power button on a 2012 MacBook Pro
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ali Court さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 7,773
