メインコンテンツにスキップ
統合されたディスプレイを持たない一般的な据え付けのコンピューターです。
2133回答 すべてを表示
My gaming computer was used to be high graphics
My gaming computer used to have amazing graphics than suddenly my graphics started lagging then I changed it to Medium graphics it was still lagging then low it stop lagging. Please help
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
What are your PC specs, and what game are you trying to play?
さんによる
コメントを追加
3件の回答
最も参考になった回答
Do you have your hdmi/vga whatever plugged into the graphics card output or integrated cpu graphics? There will be 2 sets of output ports on the back of your PC, the graphics card set is usually the lower one but it depends.
EDIT: Also check task manager to see if anything is going on in the background eating up system resources. It could be a windows update slowing you down.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
That work but I have a question for you.
さんによる
But the but when I using the app it shows it and need to do it every time. There is a way to rid of them automatically?
さんによる
https://lifehacker.com/pause-windows-10-...
You will need to just wait and let the update run at some point though.
さんによる
コメントを追加
It can go down hill over time as heat build up on the gpu. I would clean the cooling system and if that dosent help and the temperature dosen't go down then a operating system reinstall may be in order.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I did check but wasn’t problem . But thanks
さんによる
コメントを追加
Is this the same game? If not, then you need to upgrade. Of course, suppose a PC is not taken care of properly and cleaned from time to time. In that case, large quantities of dust could cause the hardware to overheat and throttle, but if it's outdated, all you can do is upgrade. It is straightforward to do if you have general knowledge about how computers are built; if not, a Youtube tutorial should solve that for you. The trick is to buy a good motherboard that will allow you to upgrade in the future and make sure that the components are compatible.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
MDA gamer さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 114
