メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
iPhone 5s Stuck in recovery mode has black screen
I started having problems with my Iphone when 3g stopped working, wifi was good. Reset it still did not work. Couple hours later i was watching a video off youtube and it just crashed. Tried turning it on no response, plugged it into itunes which says it is in recovery mode and gives an option to restore but that will wipe everything and i have pictures that i have not backed up to icloud yet.
Got a Program called Reiboot that claims it could get around wiping the phone, detects the phone correctly dowloaded the correct firmware goes to "repair it" the apple logo appears then fades a couple of times then i get an error from the software to try again (this is the only time i get the screen to display anything, even when it's connected to itunes)
I have tried holding down the power and home button with itunes to get it out, it just disconnects and reconnect and itunes declares that it is still in recovery mode. Is there anyway i can recovery my photos and such before i try restoring it? i have tried 3rd party software but they cannot detect the phone and i can't use the default import option on windows as i can't select "trust this device" on my phone as the screen is black.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
there might be a hardware problem with the device. restoring might be the only thing you can do but i would try unplugging the battery for a few hours and plug it back in to see if it will come back to life. i am not sure what else to say as i have not seen this before.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Try downloading Redsnow. Go to extras and Recovery mode loop fix. It saves phones for me all the time. (Obviously when the phone is plugged in.)Hope it helps! If not I do have some other solutions.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
hey!! what other solutions do you have?
さんによる
コメントを追加
its hardware problem hard disk error
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Lightsfaster さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 2,288
