メインコンテンツにスキップ
Repair manuals for HP's "Mini" series of small form factor netbook computers.
52回答 すべてを表示
Cracked Display Replacement Procedure...Tips?
My son inadvertantly cracked his netbook screen/display and we intend to replace the broken screen with a new one that will arrive in the next day or two. Anyone have tips for the most expedient way of detaching the screen bezel and opening the keyboard for access to the plug-in and such? A step-by-step would be very much appreciated if anyone has done this with their own HP netbook. Thanks a million.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Dave, there are so many laptops, and netbooks etc. that it becomes tough to keep it all in mind. That is why I try to always get a service manual before I get going on things :-) Anyhow I do have the one for your HP110 and I made it available to you for download at http://www.keepandshare.com/doc/2617573/... Can't get any more step by step than the manual. So if you download it you will have all the information needed for your task. Good Luck and let us know how it went.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
You order new replacement screen online by checking of desired model. Once your recive the replacement screen then you can follow the online tutorials to follow the instructions if you are confident about your technical skills. Otherwise take it to hardware shop and get if fixed from there.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Dave さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 874
