Samsung smart tv better
Why can i do to fix my samsung tv if it has a broken screen
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Saga Manga a repalcment screen will cost you more than a new TV if it is even available. You can try and do an online search by using the manufacturer label from the back of your panel. do a search based on the model number of your panel. Sometimes panels are used by different TV makers and you might get lucky finding one. The only other thing you could do, is to try is to find a TV same make and model as yours, that has broken parts other than the LCD. Use that to harvest the screen from.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 123
