Camera removal in the atrix
It appears both cameras are soldered to the ribbons. What would be the risk if I removed the cameras from the phone permanently?
Eric Rosener, if you check on the ifixit teardown of the Atrix you will notice that "This cable houses the front camera, earpiece speaker, power button assembly, and top microphone." So it looks like it might just not be possible to do that. Sorry. Here is the teardown Motorola Atrix 4G Teardown good luck with your project.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 2,099
Why do you want to remove the cameras permanently? Some security issue at work? Maybe some gaffers tape would be sufficient.
John DeRosa さんによる
Security at work is the reason. The only option is complete removal.
Eric Rosener さんによる
