Why is one of my propelers is not working
Every time I turn my drone on one of the propelers won't work
Do you still have it?
There is a screw that goes through the propeller and the shaft, on the bottom gear you have the same set up. the screws will shear in the shaft preventing a simple replacement. You may have to drill out to free the broken screw inside the shaft, through the top worked for me
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 9
今までの合計 351
It could be the screw that holds the propeller to the shaft; sometimes the break
lild.james さんによる
