メインコンテンツにスキップ
Released in 2014, this pay-as-you-go Android Smartphone provides convenience with an affordable price.
13回答 すべてを表示
Why LG Optimus cant fully boot? It keeps shutting down and restarting.
I have an older model LG Optimus Fuel, and it has been fine except for running out of memory, so I kept having to delete apps to free up memory. Now When I turn it on, it can't seem to finish a complete boot cycle--it just gives up after a bit and restarts itself. This will continue indefinitely unless I take out the battery. No combination of holding down any buttons seems to bring it to a new, safe mode or memory. There doesn't seem to be anything i can do except hit the factory reset button. Is there anything else I can do?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
This is not the case, as my battery usually lasts more than a day at a time. Thanks, though
さんによる
コメントを追加
2件の回答
Jc H the very first thing you want to do is to replace the battery. A failed battery (no longer holding a full charge and/or supplying full amperage) could cause symptoms like you describe.
Update (12/26/2017)
Jc H if this is still the original battery, it is absolutely possible that it is failing. This does happen from one day to the next. If nothing else, a new battery will give you a known-well starting point.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thanks, I will try that. It seems dubious to me, because it still happens when it is plugged in, or when the battery is at 100%. But I have been using a different charger cord lately, and that could account for it.
さんによる
コメントを追加
I have this too, I replaced the battery a month before it began so I know it s NOT battery related.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jc H さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 6
今までの合計 376
