I have forget pass my word.
i have forget my pass word
この質問は役に立ちましたか?
If you cant power off the phone remove the battery .This guide shows how to open the phone and remove the battery
Samsung Galaxy J7 Teardown (video)
Once you've got the phone of follow this video on how to reset the phone
https://www.youtube.com/watch?v=9gSyRbrq...
Hope this helps
このアンサーは役に立ちましたか?
A hard reset may be required to bypass a lost password.
このアンサーは役に立ちましたか?
I
can not turn off the phone with out the pass word
the reset varies on android phoned, sometimes it is Press and hold the Volume Up key and the Home key, then press and hold the Power key.
When the device logo screen displays, release only the Power key...
or
hold together: Volume Up + Home + Power button for a couple of seconds. You should relese held keys when the Samsung Logo appears on the screen. Then select from Recovery Mode menu "wipe data / factory reset" using Volume buttons to navigate and Home key to confirm.
or
Press and hold the power button, then press and release the volume up button. Now you should see “Android Recovery” written on the top together with some options. By pressing the volume down button, go down the options until “Wipe data/factory reset” is selected. Press the power button to select this option.
non is not working bro....nedd help plz
If you need more ideas for hard reset any phone please visit this site https://www.hardreset.info/ I found here very interesting solution to soft and hard resets for my phones.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 4
過去 30 日: 9
今までの合計 111
