Sound with no picture
My Visio e6011e3 has sound but no pocture
この質問は役に立ちましたか?
@twiggy1967 turn your TV on in a darkened room and place it on a station where you know you would have a signal. Shine a flashlight at an angle against the screen. See if you can make out any movement etc. ion the screen. If so you know you have an issue with the backlight. Unplug the set and remove the back of your TV then take a look at all the boards. Check for any obvious damage like domed, leaking capacitors, loose wires etc. After that check the fuses on the power supply as well as the T-con board. Post some images of your boards with your question so we can see what you see. Use this guide iFixitでの質問に画像を追加する方法 for that so we can see what you see and hopefully guide you some more.
このアンサーは役に立ちましたか?
VIZIO TV E550i-B2 has sound and video light but NO Picture Images.
screen has sound and dark light background with no images displayed on screen
I was reading related issue's and one young man said he FOnzied the back of the TV and wala it worked thanks for the temp fix wife can watch the game
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 13,099
