メインコンテンツにスキップ
Furby was a popular electronic robotic toy resembling a hamster/owl-like creature which went through a period of being a "must-have" toy following its launch in the holiday season of 1998, with continual sales until 2000. Furbies sold 1.8 million units in 1998, 14 million units in 1999, and altogether in its three years of original production, Furbies sold over 40 million units.
85回答 すべてを表示
Changed Furby 2012 motor, how continue? Gear? Reset? More?
Our zebra striped Furby 2012 had a hard fall and became "narcoleptic". Waking up, no movement, half opened lit eyes, talking a little and just shutting off within half a minute. Following other posts, I opened the Furby, was able to remove the 6V DC motor and test drive it and see it was no longer functioning. Ordered a new motor on Ebay, got it installed and now.... what?
Now I have new problems and need help. Furby moves and sounds but is completely maniac. I suspect that the gearing needs to be in a starting position, but I have no Idea how to get there. I only find results for old Furby gear online. There may also be something else, but I've come to the end of ideas.
Anyone that has come this far and managed to solve it? Other ideas? Anything is appreciated.
/Ulrika
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
Ok so once you get the 6V DC motor, you’ll need to solder it on the pre existing motor wires, you got the furby moving which is good, but the sound is an issue. So if its coming from the speaker, the speaker might be damaged from the fall and sadly might need replacing. If it’s just the gears grinding, I recommend using WD40 lubricant, it will help a smoother flow of movements and limit the sound. If you feel as if you can’t do anything else with the gears, you could find a replacement at stores such as Skycrafts or RadioShack. I’m hoping some of these pictures may help:
Also here’s a guide: Hasbro furby 2012 DC Motor Replacement
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ulrika sweden さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 116
