メインコンテンツにスキップ
モデル番号A1708/EMC2978ー2016年10月発売。このエントリーレベルのMacBook Pro にはこれまでと同じファンクションキー(OLEDTouch Barとは反対)が搭載されています。ファンクションキーモデルにはIntl Core i5と2つのThunderbolt 3ポートが付いています。
Display switches off when opened more than 45 degrees
Hi
I have a late 2016 13.3" MBP with function keys. Lately, I've been facing an issue where the screen will go black(dim) when its titled more than 45 degrees. It's out of warranty as well
I am still able to make out the contents on the display using a flashlight. Went to the Apple Store, they want to replace the entire display assembly and are asking for $650 dollars for the same
Is there any fix for this?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
最も参考になった回答
We don't have any guides yet on the new 2016/17 MacBook Pro's. But the teardown can give us a clue on whats happening MacBook Pro 13" Function Keys Late 2016 Teardown. If we jump down to Step19 we can see how this series inter-connects the display and the logic board. One of these ribbon cables is likely damaged in some way.
Carefully pop off your bottom cover and do an inspection of the connectors do you see any staining from liquid damage? Do you see any distorted parts or missing screws? Take some images so we can see if you see anything.
Most of us tech's haven't seen them yet as most issues are still covered under warranty. Do be careful as this still maybe covered under an extended warranty issue (defective part type of issue) so you don't want to mark your system that you've been in it.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I haven't yet collected the laptop from the diagnostics. Will try and attempt to check once I get it back
さんによる
コメントを追加
回答を追加する
Saurabh Jain さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 9
今までの合計 5,181
