メインコンテンツにスキップ
モデル番号はA1706 / EMC 3071ー2017年6月発売。この13インチMacBook ProはKaby Lakeプロセッサが搭載されています。最大4.0 GHzのTurbo Boost付き3.5 GHz Core i7です。
276回答 すべてを表示
Is there a way to disable battery charging MacBook Pro 2017 TouchBar?
Hi
I have a question is there an option to disable battery charging by software or hardware.
I remember Macbook Pro Unibody 2011 magsafe plug - if you cover the middle pin the battery will no charge, and only the power from the socket will go trough and power the laptop - I used that method when I had that model.
Bu t now I have Macbook Pro 2017 TouchBar and I bought Baseus cable kind of magsafe plug but it has only 5 pins, I tried all variation to cover each pins and all combination, but not success, As I'm not electrician guy I can't test it further.
So my question if some one has that kind of Macbook and Baseus AC Cable with magnetic plug can you test it
Thanks to all
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
5 件のコメント:
Any one can help me with my question
さんによる
Please does anyone can help me with my question?
さんによる
Hi again is there anyone...?
さんによる
What kind of Baseus AC Cable did you get and why?
さんによる
さんによる
コメントを追加
3件の回答
I am sorry since there is only a poor idea that I can give you about this which is to open up the your macbook and disconnect the battery from the motherboard. From there on, your mac will work 100% dependent on the DC power supply, which is also inconvenient if the charger is disconnected your mac will turn off.
What I also wonder is why do you want to do that in the first place? Is it about the battery cycle?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Here I'm also interested in the subject. It is an issue of battery cycles in my case, limited to a thousand before battery performance starts to decline in recent models of Mac book. I'm a heavy user of my laptop and need to charge it twice a day. That only gives about a year and a half before battery starts to decline. I used to remove the battery of my HP laptop during the day, hence that laptops battery is 5+ years old and still in good shape.
さんによる
コメントを追加
I am especially interested in the question, how to turn off charging, because:
I want to be able to unplug the charging cable whithout cutting the current with the physical connection by doing this. I think after x time unplugging with a “lightning” in the plug, the plug will be burned out.
Similar to the programm Jettison, that allows me to eject external discs before going to sleep, I would like to have the possibility to turn off charge, may be for 30 minutes or so, or to stop it until the battery is discharged to let’s say 40% (needs to be defined. Both would help.
Please programmers, work on that!
Thank you Andreas
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
(Sorry for my very bad english xD) Unfortunately it is not possible to disable charging. But if your MacBook is charged to 100 percent the system automaticly stops charging so your battery doesnt get damaged over time. I have the same problem because my MacBook is also plugged in an external Monitor which charges the MacBook via USB-C. So it also gets charged constantly. But however it doesnt seem to harm battery life.
Hoped that helped you :)
Greetings from Germany.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ivv さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 15
過去 30 日: 31
今までの合計 4,107
