メインコンテンツにスキップ
The Motorola DROID MAXX is the successor to the Motorola DROID RAZR HD.
20回答 すべてを表示
Shows charging but then says isnt charging
I replaced a customers screen and battery on their Droid maxx 2 and now the phone shows the lighting bolt saying the phone is charging but when I go to the settings and go under battery it states that the phone is not charging and the battery percentage is not moving, can someone please help me with this issue? PS I removed the wireless charger per customers request
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
there is a possibility that the port isnt transferring the current properly. i would suggest replacing the port, to see if that works.
however, you could have a board failure, or software corruption as well. a factory reset would fix a software corruption.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
If it wasn’t the battery that is busted then it means that you are using a power adaptor that is not giving enough power to charge it. I do hope that the phone is currently is working! Sorry if I came in way late.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
cellphonebuyer1 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 152
