メインコンテンツにスキップ
モデル番号はA1059もしくはA1099/20、40、60GBハードドライブ/タッチ反応クリックホイール
227回答 すべてを表示
締切られた回答
Hard drive cable has disconnected how do I re-connect it?
I have seen the guide about lifting up the flap on the connecting strip, however my IPOD Photo does not have this connecter and the hard drive cable is seemingly only held on by tape?!?!?!
I have it all in pieces with new parts but cannot figure out how to re-attach this cable.
Ideas?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
just a really simple question. Did you check under the tape? Every iPod that i have has the tape over the connector. like iTronicsRepair mentioned, look for the black locking tab on the connector and you will have to flip it toward the cable to open the connector.
さんによる
コメントを追加
1 件の回答
ベストアンサー
If you do not see the little (i believe black) tab that should flip down to hold the hard drive connector in place, there is a good chance it has been broken off the motherboard. You can either try to just stick in the hard drive connector and hold it on with tape (probably not a good long term solution) or you'll probably need to get a new motherboard.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 1,039
