Why does my 2002 Trailblazer stall when accelerating?
I got a 2002 Chevy TrailBlazer LT 4WD and it runs fine when cold but as soon as it warms up when you are sitting and idling it is fine but when you go to push on the gas to move the engine stutters and sometimes shuts off immediately and will continue to do so for the remainder that the engine is warm. Anyone had this problem before or know what could be causing it?
この質問は役に立ちましたか?
5 件のコメント
Hi,
Get the OBDII port scanned. AutoZone do it for free.
Any error codes will hopefully pinpoint the cause of the problem.
jayeff さんによる
Tried that it isn't throwing any codes.
brucebwp2 さんによる
Did it stall out while the OBDII was connected? Because if not, maybe wait for it to stall out while connected so you can see what happens when it stalls out.
Aiden さんによる
It finally set off 3 codes today they are P0420 P0128 and P0014
brucebwp2 さんによる
Guy bought the car from hooked it up to a professional machine and cleared all of the codes in the data stream. He said they put new cam sensor and actuator on before they sold it but now it is throwing the code P0340.
brucebwp2 さんによる
