Replacement Timer for Intermatic Landscape Light Transformer
Would like to repair this unit rather than replace it. The timer mechanism has worn out and will not turn on the transformer when the tripper reaches the set time. It stalls at the set time and apparently slips when the tripper engages the switch. The part tag shows the timer as Intermatic PB115M2 but internet search shows no results. Any ideas? Thanks!
この質問は役に立ちましたか?
3 件のコメント
As a followup to this issue. I was unable to find the timer mechanism but was able to replace the light sensors in my two boxes. The light sensors are still manufactured by Intermatic (Intermatic K4021C 120-Volt Fixed Position Thermal Photocontrol) and the system now works fine as a dark to daylight controller. Not completely fixed.... but functional and not in the Landfill.
Steve Mattson さんによる 共有
I have the same problem too. I dont want to spend another $200 for new transformer just because of the timer..
jari doman さんによる 共有
I have the same problem too. don't spend extra for new transformer just because of the timer..
usha sorkin さんによる 共有
