メインコンテンツにスキップ
2015年9月25日にAppleから発売されたiPhone 6Sの修理情報とガイドです。モデル A1688、A1633。
2690回答 すべてを表示
Battery doesn’t hold the charge for long
Thank you already if you’re reading this
So I’m facing another problem with my iPhone 6s
After iOS update my battery won’t last more than 2 hours stand by or on screen use
I have already changed 2 batteries in 10 days thinking of the first battery was defective but i guess not
I have friends whose 6s working fine after the update but not sure what’s wrong with my iPhone 6s
I took my phone to nearest technician, he said that he will have to look into the logic board for some IC or something
Not sure what to do,
I have even tried restoring using all possible method ( DFU & iTunes restore )
The doubt I’m having is wether the problem is with the lastes iOS firmware or there’s something wrong with the logic board
One more thing if that helps
My phone is charging faster than usual and drains accordingly
Battery cycle is good, charges percentage by percentage no jump at all
Battery wear level is at 0% ( battery life app )
Pls help
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント:
@aman did you ever get resolution on this issue? Just in the past 3-4 days, I'm having the same issue.
さんによる
コメントを追加
2件の回答
Well apple said that they are releasing a new update that will fix that the software that made got messed up after released and I’ve had the same issue with multiples so all I can say is wait but till the new update then the new battery will keep your phone charged all the time!
If you have any questions or concerns please comment below! Thank you
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I’m already updated to 11.2.1, not sure how long i have to wait
さんによる
The next update will be in about a month or two but it will 11.2.2 so it will quit then.
さんによる
コメントを追加
The charger is probably broken and most likely to bring to store for new one
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I have 3 iPhone chargers tried all three but no luck
さんによる
コメントを追加
回答を追加する
Aman chadha さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 17
今までの合計 7,922
