メインコンテンツにスキップ
モデル番号はA1238/80、120、160GBハードドライブ/ブラックもしくはシルバーメタルフロント
904回答 すべてを表示
Why can my laptop power my iPod but not recognize it?
So I replaced the battery on my ipod and it has come to life-only when plugged in. I can go through the ipod see and listen to all my music. But why doesn't my laptop recognize my ipod. It will power it but it doesn't recognize it. It did for a brief moment with the new battery then nothing. I was hoping to pull off all the music.
TIA!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Well, assuming it's Apple have you tried with iTunes?
If it doesn't work after then, I think there's most likely a problem with permissions of your computer OR iPod that prevents you from seeing or transferring files.
And a tip: If it doesn't work on your computer try another computer, it might be just your computer in that case
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Well last night I tried a different 30 pin cable and it connected to my laptop for a brief moment. In itunes I got a warning that the ipod was corrupted and needed to be restored. I tried using Wondershares trans manager to save the files but it would not connect to my ipod-it did try but wouldn't connect.
さんによる
But have you actually tried to restore?
さんによる
コメントを追加
回答を追加する
Arun Ahuja さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 39
