メインコンテンツにスキップ
The Panasonic Lumix ZS50 is a small, lightweight personal travel camera, released in March 2015. The ZS50 features a long lens (30x zoom, 24-720mm), heightened low-light sensitivity, built-in viewfinder, and a 12.1 megapixel resolution.
7回答 すべてを表示
When I zoom in a little, the view becomes blurred.
At first, the view is in focus. After I begin zooming in very much (yes, I can hear the motor) the photo view becomes blurry. (I see 1.6 across the screen) If I try zooming back out all the way, the photo view stays blurry; however, if I turn off the camera and on again, the photo view again is clear until I try zooming in very much I have reset to factory and that did not change the problem. Yes, I am a novice.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
If your camera is on AF-S, half-press the shutter button to refocus. If it is in AF-C, it should focus automatically, but always half-press the shutter button before taking the picture to be sure the picture is in focus. Be sure pre-focus is on if your camera has that setting.
Here is the manual if you need any help:
ftp://ftp.panasonic.com/camera/om/dmc-zs...
Hope this helps!
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Sara Thomas さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 34
今までの合計 1,298
