メインコンテンツにスキップ
The Pontiac Grand Am is a mid-size size (and later compact) car produced by Pontiac. The 1999-2005 generation is the final generation of the Pontiac Grand Am.
150回答 すべてを表示
99 grand am 2.4 starting problems
I tried to start it after work and battery light came on.. it started though. Forgot something turned off went inside then nothing at all. Sometimes it'll click sometimes it'll try and crank.. it will start after getting jumped but as soon as cables come off it dies. I've temporarily been driving with jumper cables from my battery under the hood running to another battery in the backseat but once I run out of charge it dies. Alternator was tested good. Could this be a relay or fuse of somesort?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Have you tried replacing with a new battery? The altenator charges the battery, the battery starts your car. An old mechanics tricks is while the car is running, diconnect the battery. If the car dies its the altenator, if it stays running its the battery. Could be a silonoid, or starter as well. Taking it in for testing and service is sometimes the best option. Hope this helped.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
We've tried several different batteries all which show full charge .. none grand new. But if it were the start or solenoid it wouldn't dtart5 at all even with a new battery right?
さんによる
Also tested the alternator and it came out golden waiting on new connector clip to alternator to diagnose again
さんによる
コメントを追加
回答を追加する
Ericka さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 514
