Where Can I buy replacement Capacitive button array.
I broke my capacitive buttons. Any idea where i can get a replacement? Specifically I tore the flex circuit on the "back button" end.
Phil the only ones that I know off that have some parts are http://www.aliexpress.com/wholesale?Sear...
http://www.dellstreakrepairs.co.uk/spare... and of course Dell itself. Hope this helps with your repair. Good Luck.
Here is a quick update. Talk to these guys and see what they say.
このアンサーは役に立ちましたか?
Thanks. I did not see it on those web sites. I will e-mail a request to dellstreakrepairs.
Hey Phil,
the same happened to me today! =(
Did you get a replacement for the circuit and if so, where did you get it? :)
I too have just done the same thing, anyone got an answer to where I can get one?
Chris, April 15
Hey Phil,
このアンサーは役に立ちましたか?
Chris, April 15
このアンサーは役に立ちましたか?
No luck. There is some more information here:
このアンサーは役に立ちましたか?
Now in stock! http://www.dellstreakrepairs.co.uk/spare...
このアンサーは役に立ちましたか?
same link as in my first answer....:-( and it only took you seven month....;-)
Extra be it very late so its here for latecomers.
I found my volume down was not working, put up with it for 6-9months did it really matter, well yes if you need to do a reset.
Having changed 2 screens now I presumed I'd disturbed the ribbon in the connector. My presumption was spot on it was quite loose making on most but not all contacts.
I fitted a thin piece of plasticard type material, keep it thin, the thickness of the ribbon should suffice.
Sussed and sorted, I now have full volume control
Alan
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,828
