メインコンテンツにスキップ
Wi-Fi版iPad Mini 2の修理ガイド。2013年10月22日発表、11月12日発売。iPad mini 2はiPad mini Retinaディスプレイモデルとして知られ、iPad Airのすべてのピクセルを7.9インチに小型化しました。
220回答 すべてを表示
iPad mini 2 won’t charge
I’ve since replaced the battery and was initially very pleased to see it turn on. Then, the shocker; it has power, which I assume was loaded on the battery before shipping, but it still will not charge.
I’m guessing the problem therefore actually lies with the lightning port in the iPad. I would be happy to also replace this, but... what am I looking for to order/replace?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
They are soldered into place, so unless you can do logic board repair its not going to be one you can do, as I pretty much guarantee you'll end up pulling pads when you remove the old port from the board.
First thing id do is get a microscope or magnifying glass and check you have nothing in the charge port at the back. Then check if you have any broken or bent pins inside the charge port.
If the charge port looks ok its unlikely that its the port, its not like the iphone ports that have components on them, the ipad flex is basically just a wire with a plug on the end so not really much that can go wrong with it.
If its not the charge port its going to be a component on the motherboard, so you need to speak to someone in your area that does logicboard repairs.
The mini 2 does have the same piece of cr*p power management chip the air 1 also has which does suffer from charging problems, so could be fun to fix if thats the case.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jeffrey Rarey さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 11
今までの合計 2,119
