Where is the camshaft positioning sensor located 1.8L
hi, can someone let me know where this is? 2011 Elantra 1.8L
thank you
It is in the front of the engine, down low, just to the right (as you are facing the car from the front) of the oil filter.
このアンサーは役に立ちましたか?
This is erroneous! This is the location for the crank sensor.
No it's not that the crank sensor can sensor is on top of motor.
@rnps old question and just to clarify. The camshaft position sensor is (are since we do not know if this is a 1.8L DOHC engine which would have two) located under a cover on the TOP right of the engine.
image credit goes here
Hopefully you got this fixed within the last 4 years :-)
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 12
過去 30 日: 76
今までの合計 4,049
