メインコンテンツにスキップ
2016年3月に発売された4インチのiPhone。ハードウェア仕様は6sに類似しています。シルバー、スペースグレイ、ゴールド、ローズゴールドのカラーが揃っています。16/64 GB容量、Model A1662とA1723
Dropped iPhone SE in water, help
I dropped my phone in water for one second(at night). I dried it off and used it for a few minutes, and then plugged it in (bc it died, bc it had a low battery when i dropped it) . The next morning it said it was only at 1% battery, but it worked for several hours. It was searching for service (it still is) I kept it in rice for 2ish days, and the battery was still not working right, and searching for service. It's been about 5 days more or less since it was in water. The Touch ID feature, as well as the microphone is also not working. I opened the sim card tray and the LCI sticker was still white. Is anyone able to help?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
2件の回答
ベストアンサー
Juliathebooknerd Fo' life!!!! First off Rice does not work, you might be wasting valuable time. It does not stop corrosion nor will it fix any shortcircuit. Keep in mind that water damage is the hardest to troubleshoot and to repair. It does not matter if is was exposed for 2 seconds or 2 hours, what matters is where the water (particulates) did the damage. As with any other liquid immersed device you need to follow a few steps for proper trouble shooting.
stop continuing to try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse.
The very first step I would take is to disassemble your phone. Use these guides iPhone SE (1st Generation) to help you disassemble your phone. Take a careful and close look at all components and connectors. Truly assess the damage. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. You will have to remove all the EMI shields. If you do not remove the shields, you are not cleaning the board. Once you got the gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for an Apple iPhone 3G but it is still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning. Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later on. You do not need to leave it to dry for a day. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate the water. The importance here is the cleaning. It would of course be best to get it professionally cleaned Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now. After that, reassemble your phone and re-evaluate. For as long as you have not cleaned your board and replaced the battery, everything is just a guess. The longer you wait the less likely your chances to revive this phone.
このアンサーは役に立ちましたか?
スコア 4
3 件のコメント:
I've only had it since Father's Day this year. How many LCI stickers are there in my phone? If the ones inside of my phone are red is my warranty void?
さんによる
My Brother in law used the rice method to dry out his phone that he got wet while Kayaking. (Don't ask) Not saying it's a good method, but it can work in some situations.
さんによる
@sgtmoose hose are situations where doing nothing would have been just as effective. No big deal but it is shown that it does not work. It's all good.
Juliathebooknerd Fo' life!!!! yes it is.
さんによる
コメントを追加
the screen will need to be taken off to check for damage, there are more liquid indicator stickers inside the phone
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
How many lci stickers are inside my phone?
さんによる
there is around 3 or so
さんによる
コメントを追加
回答を追加する
Juliathebooknerd Fo' life!!!! さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 24
今までの合計 32,583
