メインコンテンツにスキップ
2015年9月25日にAppleから発売されたiPhone 6Sの修理情報とガイドです。モデル A1688、A1633。
2692回答 すべてを表示
Device won't power on after screen replacement
Hi! I'm relatively new to smartphone repair, but been in IT for years. I've run into an odd issue with a screen replacement on an iPhone 6s.
With the original screen connected, (with no home button) the device powers on and responds to the vibration rocker switch.
I turn the device off, swap in an identical replacement screen from ifixit, (albeit white instead of black, also with no home button) and the device REFUSES to turn on.
Done this about 10 times with the same results, so I'm fairly certain I'm not shorting the phone out with the replacement screen. What could possibly be wrong?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
did you try the old screen after the replacement, if so does the vibration work again
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Yep, the device *only* powers on and vibrates when I have the original LCD cable connected. I suspect it may be a damaged connector.
さんによる
コメントを追加
You may have gotten a bad screen .
Is there 1 connection or two
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
There are 3 total connections, I ordered the full assembly. But the phone refuses to power on with anything other than the original screen display cable. I suspect the connector on the logic board may be damaged...
さんによる
Try plugging in just the lcd and touch connector (leave the small one to the right off) and see if it comes on. Sometimes the front camera flex can be faulty causing this issue.
さんによる
Unfortunately I tried every possible arrangement of connections. The only way I ever get the phone to power on is when the original (broken) display connector is attached. With or without the other 2 connectors. If the original display connector isn't attached, it doesn't power on...
さんによる
コメントを追加
回答を追加する
Bay さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 54
