メインコンテンツにスキップ
Released June 2014, identified by model number 15-d076nr
7回答 すべてを表示
Not charging or wifi connection after new hard drive
My sons laptop stopped working blue screen with code took it to a local repair place they changed the hard drive but now wifi connection is really weak and drops out also it won't charge at all I've tried disconnecting and reconnecting wifi well until battery give way also tried two different chargers one brand new official hp charger no joy the woman said she only changed the hard drive and didn't go near anything to do with wifi or charging but before there was no issue at all with either of the above
Any help would be thoroughly appreciated
Kind Regards
Mr O
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Download HP support assistant and check if the newest drivers are installed.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Ok il try this and get back to you. Thanks
さんによる
コメントを追加
回答を追加する
Gareth Owens さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 80
