I need help please
hey im new here i have a sony bravia smart tv recently when i play my xbox one i power cycles my tv ....at weird times it should not turn my tv off and on when i play ,,,at all please help....thanks in advance
there is a feature that allows you to control your TV with the console.
http://www.ign.com/wikis/xbox-one/How_to...
This may be acting up. Try turning it off. If it still happens, it is either the TV, or the outlet.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 147
@luckylastone what exact model is your TV? Does it work with other input sources correctly?
oldturkey03 さんによる
kdl-40w600b And thanks in advance.
luckylastone さんによる
@luckylastone Does it work with other input sources correctly? This willdetermine if this is a TV issue or an input issue.
oldturkey03 さんによる
it seems to be working now since i unplugged my usb drive it dont do it kinda of weird???
luckylastone さんによる
Well, Sony TVs are programmed to look for firmware updates on the USB stick. Maybe there's something on there?
S W さんによる
