メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2016年9月16日に発売。モデル番号は1778,1784。 GSM かCDMAの32、128、256GBがあり、色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラックがあり。
Bent iPhone 7 plus
I recently brought my phone to the Apple Store for problems i've been having with my phone. They then discovered that I have a slight bend on the rear housing.
My initial problem was that when I turn it on the phone flashes a white screen with the apple logo. I've tried rebooting it through iTunes at times it will turn on and allow me to set up as a new phone but it doesn't stay on, and when it is on when i make or receive phone calls I can't be heard.
In addition the camera and voice recorder is not working, is there a possible solution to this? I'd rather not give in and bring it to Apple for repair. Any help is appreciated!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
A bent frame can cause logic board damage. It may be fixable but it's hard exactly what the issue is based on what you shared in your question. The only real option other than an Apple OOW replacement is to have it looked at by a reputable micro-solderer. The risk with bent logic boards is that the damage could be "inside" the board and therefore not truly fixable.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
For iPhone 7 bent frames, generally apple OOW is the way to go, I haven't found a way to bend them back in place.
さんによる
Is there a way to test what the exact issue is?
さんによる
コメントを追加
回答を追加する
almarie さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 1,586
