メインコンテンツにスキップ
2013年11月22日に発売されたMicrosoftの第三世代のXbox ゲームコンソールです。
E100 Code on start up and wont apply Update
Hi, I've got an issue with my Xbox One console. when I turn on the Xbox it doesn't give me the start up green screen. It goes straight to something went wrong and gives me a error E100 code. I was wondering is this a Hard Drive Issue? OR a Disk Drive issue. I really don't want to buy a new Xbox. Hope someone can tell me the issue thanks in advance.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 17
10 件のコメント
If you are still having this issue I just fixed mine. I removed the hdd from the xbox and hooked it up to my pc. Accessed the system update 1 partition and deleted all the files and reinstalled the hdd. Then took a flash drive (any drive over 8gb will work) and formatted that to NTFS and extracted OSU1 to it and inserted it into the USB port on the xbox. Booting the xbox by holding for 15 seconds, the bind button on the side and the eject button and pressing the power button. The console then fully went through with the system update. Afterwards i just had to redo the initial setup but all my games and saves were still there. Hope this helps someone else.
さんによる
justin wedel buenas tardes ami igual me aparecio ese error asta compre otro disco duro y me aparece lo mismo entonces tengo que hacer todo lo que acaba de decir osea formatear desde mi pc el disco duro ? y luego conectarlo a mi xbox one y poner un usb con el osu1? contesteme porfavor
さんによる
How would I go about hooking up the HDD to my PC . I already removed it from my xbox?
さんによる
Hi jake, you should be able to find a cheap usb dock under 20 bucks on amazon or eBay that would allow you to easily hook it up to your PC. If you don't want to do this you will have to install it in your PC as a secondary drive.
さんによる
Great thank you
さんによる
5件以上のコメントを表示
コメントを追加
4件の回答
ベストアンサー
To resolve this problem, use the Xbox One System Update Solution:
Go to the Xbox One System Update Solution.
Select I am getting an error message or an error code.
Select I am getting an error code.
Scroll down the screen and select E100 XXXXXXXX XXXXXXXX.
Follow the instructions in Step 4 to successfully update your console.
このアンサーは役に立ちましたか?
スコア 3
4 件のコメント:
Absolutely useless answer
さんによる
I agree.
Even with doongrall the steps... Still get an error code
さんによる
Make sure your disk drive didnt come unplugged. i shipped one to my bro and thats what happened.
さんによる
This helped ty
さんによる
コメントを追加
I have an original Xbox One and only run into this problem once a month or so.
When the troubleshoot screen appears, select “turn off Xbox.” Once it’s completely through turning off, unplug the power box from the power socket and the Xbox itself.
Wait around 10 minutes and plug the box back into the socket. I waited a minute-ish and plugged it into the Xbox.
Manually open the troubleshoot by simultaneously holding the “sync“ and “eject” buttons while also pressing the power button. Wait for the second tone, and select “reset but keep games and apps.”
This was successful for me and I hope it helps someone else!
このアンサーは役に立ちましたか?
スコア 2
8 件のコメント:
I unplugged and waited for it to cool off and held all 3 worked like a charm! Only Reset factory that worked for me!!! (went to back to 720p resolution. That how I knew I got a good reset out of it ) thnx for the Tip! Hope everyone lucks out with this tip!
さんによる
Hello . I have a different problem my x box one s is stuck on update since 2 weeks. I have tried the ous1 and nfts methods but its stuck on 56%
If anybody could help me then please
さんによる
if it is stuck on 56 % has bad hard drive
さんによる
This happens if you installed a new disc drive without changing the computer board from the old into the new! The hard drive a disc drive are married to each other and it has to think they are still together
さんによる
This happens if you installed a new disc drive without changing the computer board from the old into the new! The hard drive a disc drive are married to each other and it has to think they are still together. I switched the two computer chips and this worked excellent!
さんによる
3件以上のコメントを表示
コメントを追加
You need to make sure you have the original disk drive (they are married to the mother board) and make sure it is plugged in.
このアンサーは役に立ちましたか?
スコア 1
7 件のコメント:
I ended up fixing my e100 issue by turning off my wifi and manually updating my USB.
さんによる
What if your original disk drive was the problem and has been replaced? Also, How did you update from the USB?
さんによる
IMPORTANT! READ CAREFULLY (IT'S SIMPLE) FOR THIS PROCESS YOU'LL NEED A WINDOWS (7, 8, 8.1, 10) COMPUTER CAN'T DO IT WITH MAC LINK: http://www.xbox.com/xboxone/osu1
also i recommend you to use this procedure as you last shot, since you can HARD RESET you xbox and it may fix it, if not then you go on with this process.
you can get the latest OEM update from the xbox page, just will be needing a usb flash drive as minimum 8GB and then format it as a NTFS (since that's the format the xbox is compatible with) and then you'll take the compressed OSU1.RAR file and of course decompress it, copy the $SystemUpdate folder that you will get, put it into the drive (NFTS FORMATED) root and that's it, you will have to turn off the xbox, then unplug the power cord, press the xbox power button as many times as you can that's how you will make sure is completely off. then press simultaneously the sync button, the eject button and the xbox power button at the same time, you'll hear a "bip" but keep holding it till you hear a second "bip" that's how you get to the xbox Trouble Shooting menu, then simply select the (offline update via USB) and that's it. just need to wait for it to install, you'll need to update the xbox with this procedure just by this time, next time i'll be fine.
さんによる
What if i cant click the offline system update i have it on my used i followed all the steps but i cant click that square
さんによる
@eduardo sanchez did you format the usb pen in NTFS and extract the OSU1 file and press the sync key at the same time and expel and then the power button?
さんによる
2件以上のコメントを表示
コメントを追加
With my brothers Xbox one all he did was take it apart and unplug the hard drive and plug it back in. Worked like a charm. Wouldn’t try this with the Xbox one S
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
what would you do for the xbox one s? I have the error there and have already tried the offline update, the reset everything, and ensuring that the connections were properly seated.
さんによる
コメントを追加
回答を追加する
Elizabeth Peterson さん、ありがとうございました!
統計データ:
過去 24時間: 19
過去 7 日: 76
過去 30 日: 265
今までの合計 73,270
