メインコンテンツにスキップ
The SanDisk microSD card is a storage device/medium in the TransFlash/microSD format. The standard ones come in all different capacities, up to 2GB. It was released in October 2001.
13回答 すべてを表示
My card is physically broken, any chance to retrieve the files?
So I accidentally broke my micro SD card (Kingston 16gb) and I don't know wether I should have some hope to restore the files on it or not.
I watched a couple of videos people restoring files via soldering and so.
This image shows where it's broken (highlighted in red)
https://ibb.co/bM6opb
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
If it is just broken along the back side you might be able to stick it in an adapter and recover files(the adapter might take the card and you wont be able to get it back out, just make sure you stick it in all the way with a toothpick or a sewing needle, something along that size), i don't think there is anything in that back part of the card, but i might be wrong. If you cant recover files from using an adapter there is no point in trying to fix the card to recover the data, you'd save money and time by buying a new SD card.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Thanks!! I really hope it's gonna work because it seems easy! I'll try this out and come back!
さんによる
ill be here if you need anymore help
さんによる
コメントを追加
Hey I have the same problem and I tried it however I didn't force the memory card in my adapter just in case it didn't work but I just wanted to know if this has worked for you because I have very important work on my memory card and I'm stressing so much. Thanks!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Unfortunately it didn't work, I just gave up but I'm keeping the memory 'cause maybe in the future I could restore the stuff on it!
There are places where they work on restoring files from broken sd cards ,CDS, etc) you can send yours, it costs around 400$!
さんによる
コメントを追加
回答を追加する
Hend Usamah さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 13
過去 30 日: 59
今までの合計 5,100
