メインコンテンツにスキップ
An Uninterruptible Power Supply (UPS) is an electrical device that provides backup power to critical equipment in the event of a power outage or other power-related issues.
42回答 すべてを表示
UPS left alone, unable to power up even with new battery
I've got a APC UPS BE500-AS that's has been left alone for a few months.
When I wanted to use it, I realized the internal lead acid is already flat, and I cannot charge it up with a lead-acid charger.
I bought a new lead acid battery to replace the internal one. It worked fine for a few days. After that I cannot get it to power on anymore.
I've tried the circuit breaker switch on the side and that does not help.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
ベストアンサー
It is possible that the UPS is not charging your battery. Have you checked for loose connections and looked at the circuit board for any fuses that may be blown? here is a good forum that deals with UPS and has some schematics http://www.badcaps.net/forum/showthread....
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
If your battery has more than 3 years, get a new one !
When you turn on all UPS (especially APC) they first test the battery putting a big current in paralel with the battery. I the voltage drops below to 10,50 v your UPS does not turn on - still making some beeps.
Excuse my terrible english.
Roberto / Brazil
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
People simply do not know that their UPS requires TLC, you cannot let them sit unused, the battery requires what is called, “massaged“, it needs one of those super slow automated trickle chargers that will turn on and off when needed instead of letting it just sit.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
riDerz さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 14
過去 30 日: 51
今までの合計 17,444
