445646
1 件の回答
if your device is the 881C, you are looking at a simple back panel removal.
Just find the Groove at the bottom of the back panel of the device, and peel up.
from here The battery is a pull out: Find the groove on bottom seam between the battery and the frame, then pull out.
if you have trouble finding these grooves, there is a possability your device is not an H881C
このアンサーは役に立ちましたか?
スコア
0
