メインコンテンツにスキップ
Sony Xperia Z3デュアルはSony Xperia Z3 D6633とも知られており、2014年9月に発売されました。146 x 72 x 7.3 mmの本体サイズでIP68認証済み、5.2インチディスプレイ、20.7Mpリアカメラを搭載しています。
27回答 すべてを表示
There dust on camera sensor, cannot get rid of it..
Hi! Very helpful video! I have dust on my camera. I tore don the phone, cleaned the lens and used a rocket blower to blow the dust but it stays there. When I remove the main camera and move it around, still connected, the dust particles do not move with the picture , therefore the dust must be somewhere else inside the phone... Seems its on the sensor and the sensor is not part of the lens. Is this correct? Any ideas where this dust might be? Thanks for any help!![http://file:///Users/oisingormally/Downloads/DSC_0001.JPG]
Update (12/07/2017)
Thanks again Scott!
Here is a quick video. The camera is still connected but is out of the phone so I can move it around.
YesterdayI was convinced the dust spots did not move with the camera and I thought the dust was somewhere else than the little camera module.
But now I think you are right, I will order the replacement camera !
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
so there are two lenses relating to the camera.
there is the Shielding Lens, which keeps dustand debris out of the camera
and the Zoom lens, which is the actual lens of the physical camera
if you are getting the smudges with a perfectly clean shielding lens, then the zoom lens is likely scuffed by the dirt that was in there.
Replacing the camera will fix this issue.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Thank you for your reply! Is this shielding lens and zoom lens within the camera itself? How can I upload a short video/ pic, so you see whats going on?
さんによる
there is a media content selection while editing the original post. (Add photo)
The Shielding lens is the glass that is attached to the Back Panel of the phone.
The Zoom lens is manufactured into the camera module itself.
さんによる
コメントを追加
回答を追加する
oisin さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 25
今までの合計 1,442
