Replace 7+ digitizer with 6 +?
Can I replace a 7+ digitizer with a 6+ digitizer? I have an extra 6+ digitizer
この質問は役に立ちましたか?
この質問は役に立ちましたか?
No.
Top is the iphone 6+ (wires on top) and bottom is 7+ (wires on side AND top) as you can see, the connectors are not in the same place.
If this is your answer please mark it as answer! thanks!
このアンサーは役に立ちましたか?
no you cant because the ribbons will not be in the right place and possibly a different connection aswell
このアンサーは役に立ちましたか?
No, the flex cables are not on the same place, the iPhone 6 + is on the top and 7+ is on the bottom.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 7
過去 30 日: 15
今までの合計 137
1件のコメント
Thank you very much!
Eva Marie Palmisano さんによる
